@sburke781
trying to use your driver to get device battery data from Tasker so I can set a Zooz plug to the proper state so I can charge between 15% and 80%. For your task, could you Export the Description to the Clipboard and paste it in your reply?
I have tried both the local and cloud versions of the URL.
My values:
[Device ID] d68e78b6-a3b6-4e87-aedf-d28c1cc551bb
[Command] setBattery
[Secondary Value] %BATT
Send Device Command (replace [Device ID] with actual subscribed device id and [Command] with a supported command. Supports optional [Secondary value])
https://cloud.hubitat.com/api/xxxxx/apps/215/devices/[Device ID]/[Command]/[Secondary value]?access_token=xxxx
Updated URL
http://192.168.0.0/apps/api/215/devices/[Device ID]/[Command]/[Secondary value]?access_token=xxxxx
Updated URL
I believe that I have a something incorrect in Maker API. I get an error messege "Device not found or not authorized" in Tasker
