I've read here that the HE clock is updated every day via ntp. Is there a way to view, change, etc. the ntp configuration?
You can view and change them:
How does one get there? I tried to replace /hub/ with my HE IP and got a 404 error.
It's http://hub-ip/hub/advanced/scanForNtpServers
This should really be under network settings... poking @support_team
How does NTP operate on HE? Does it use the first responding NTP server? If I set /hub/advanced/ntpServer/IPaddress, and that server is unavailable, does it continue to search? I am currently using the NTP Client app to grab the time from my Pi, but if there is a built-in method, I would prefer it.
