I was wondering if anyone has tried the Vesternet zwave remote controllers? They indicate that they're hubitat compatible, but "compatible" is always range. I've been seeking a way to remotely do continuous dimming of lights controlled by zwave switches and modules that mimics the experience of holding the wall dimmer. So far, nothing really recreates that experience.
EDIT:
For other folks, I wrote to Vesternet and was told that these controllers are only available for EU Zwave frequencies and won't work in the U.S.
Yup but only two paddles. Was looking for more buttons.
In general though, the issue with hold/release is that many devices don't seem to support start/stop fade commands via their hubitat drivers. But that's an issue of the controlled device - not the remote.
Yeah, definitely battery powered. I've thought about the nano mote but it's annoyingly expensive. Might have to consider it though.
For the targets, I have some leviton zwave outlet modules, but they don't support either associations or the start/stop fade. Same for Shelly dimmers (the hubitat driver doesn't support start/stop fade).
It's remarkably hard to find either zwave or zigbee outlet modules with dimming for things like lamps. I guess everyone is going smart bulb these days but I prefer to have the option to use regular dimmable leds.
Also hard to find battery-operated remotes with more than a couple buttons. I don't really want one for every lamp. (I've been told that remotes are 1980s and I should just create automations but I'm stubborn about human autonomy).
Have you considered a small cheap tablet running a dashboard in kiosk mode? Could have a dock for it that charges it up and then it would also be portable. You could put as many buttons as you want on it.
Yes, I'm doing that for main living area (android tablet, fully kiosk), but I was looking for small ones to put on a nightstand, side-table, etc.
Have been trying multiple dashboard solutions on the tablet - hubitat native, hubitat dashboard android app, SharpTools, and Home Assistant. Surprisingly, I'm starting to lean towards home assistant - it seems to be the easiest to configure buttons and tiles. I thought SharpTools was going to be the winner but I've found it less intuitive and flexible than it seemed at first.
