Happy Holidays all!
I've got 3 c-7's. One is about a month old. the others are old enough as to not matter. The newest is taking 10min to download updates. It's had other problems I've posted about dashboard links, so I'm starting to wonder if it's a lemon?
My other hubs take 30sec or less to do the same download (in series not all the hubs at the same time) This happened with 2.3.0.111 and now also with 2.3.0.112. My speedtest is showing no problems at all. I've rebooted the unit without improvement, it's doing nothing really, only one rule that only runs once a day turning on/off one switch.... Not sure what else I can do to narrow it down, but it doesn't seem right. Thx in advance for any suggestions.
Check your settings > Network setup.
Set your port to 100Mbps fixed if it is not already. This was causing my hub UI to be very slow before and with that set it works great.
My C7 runs faster if it is set to Auto negotiate, it was slow when set to 100mbps.
and I thought I asked a simple question!
Interestingly on my main unit that runs dozens of rules, networking doesn't even show on the local apps list for time (logs/App). But on this slow unit I'm seeing Netowrking as the #1 time user
I'd like to add a thanks to the HE dev team for adding more info to log data to help with problem solving. Much less black box, much gooder!
