Verisure integration
Hi
I need some help with this ST Verisure App. It is needed to integrate my alarm statuses and sensors. It work good under ST. What is needed to translate the app and drivers for Hubitat?
Hi! Did you get any help with this?
I would really like to have this too.
Just need to get away/home statuses so that my Hubitat can use this condition to set away status in the hub.
Think i got a workaround :slight_smile:
All done via software and web.
It´s set up like this.
  1. Verisure notification from the official mobile app to my gmail.
  2. Gmail auto sends that email to my zapier account and sens out a GET request to IFTTT Webhooks.
  3. I created at Virtual Presance device and named it "Verisure Stauts".
  4. IFTTT Webhooks send out a GET request to my Hubitat via Maker API.
  5. Mode Manager then uses the virtual device to set the modes.
  6. My rules in rule machine then have mode conditions.
I will try to optimize this method when i get time, the zapier to IFTTT step is unfortunately nessesary at the moment because gmail has stopped working with IFTTT :frowning: and zapier can not process the long get requests that maker API uses.
Any thoughts and ideas is greatly appriciated.
I would like also to connect my hub with Verisure devices. Is the solution above the only one available please ?
HA seems to do it but I don't really want to switch to HA because of that.
Have you seen this thread @zenblom?
Send me a PM and then you can try my drivers as @ktd have done. I want more testers :slightly_smiling_face:
