(Ver 2.1.2 (328)) - Tapping on a switch in Favorites causes the UI to Refresh/Jump
Android App Version 2.1.2 (238)
Samsung S23Ultra AND Tab S9 Ultra
C7 Version 2.4.1.170 (and again tested on 2.4.1.176 with same results)
Odd behavior using the favorites section to toggle switches. I have a switch that I use to clear the queues on my wifi speakers. I have the rule set to turn the switch back off after one second (I like visual confirmation), then clear the queues and then speak on each of the speakers that the queues have been cleared. (Whenever I lose power, they seem to have issues and some fail to speak unless I do this. The hub is on a UPS, but the speakers are not.)
In any case, this switch is at the bottom of my "favorites" list. We lost power yesterday. So, I went to the app, scrolled down to the switch and tapped it. IMMEDIATELY, the screen refreshed and I was sent to the top of the screen. The speakers did not sound off as quickly as they normally do. So, I scrolled back down, tapped the switch again, and it IMMEDIATELY scrolled back up again. I tried another switch that does not turn off automatically, and it did the same. However, scrolling down shows that the tap worked. I should note that the speakers did respond with a delay (probably due to the lan coming back up and some of them being not quite ready) and continue to work without delay after clearing the queues.
So, it appears to register the tap, but then moves so quickly that you cannot see the switch turn on or off.
Wondering if this is "as designed" or a bug. Would be nice to not have to scroll back down (especially for visual confirmation on those items that revert back to the original condition after a short period of time). I also use the favorites to turn on/off multiple camera switches on occaision. Would be nice to be able to tap them all in succession without having to scroll back to the bottom of the list repeatedly.
