Hi all,
I just wanted a second opinion on the rules below, for example, if they can be combined or done in a more efficient way etc.
Note that I’ve just created rule no.4 and not fully tested, so any comments or advise on the rule will be appreciated.
EDIT: created rule no.4 as humidity readings can be a bit slow to update, so want the boost mode to be on if someone is in the shower regardless of the humidity level.
1. Boost mode (extract fan for bathroom + kitchen) – ON if humidify >=65%
