Variables and negative numbers
When writing a Rule with a variable will this variable recognize a negative number such as -15.7?
What I have is a temp sensor tapped to the side of my apartment building. When the lux gets high I assume the house warms up and increases the temp the sensor reports.
AFAIK, You can set a decimal variable to a negative value.
Thanks.
