Cheers!
I responded over in the original SharpTools community thread with a Custom Tile that should accomplish what you're looking for.
It's using a SharpTools variable as a source, but it could be tweaked to use a 'Thing' as a source instead. It should be a good baseline to get you started.
Thanks for that.
See other thread.
Once this is solved I'll hopefully be able to update this post. From what I can tell, this is unique. If this could be tweaked, I think between a few different ideas, this could create something phenomenal....
