What is the best way to make following work.
I want to go to night mode at 10pm except if the sunset+30min is after 10pm, in that case it should go to night mode at sunset+30
In the Set Mode at Times table, use the Select single or multiples times dropdown and select Later of Two Times
it sounds weird, maybe because I don't speak native english
or this?
Either way will work, the order of the two times shouldn't matter.
Yes, the verbiage in that section is a little confusing.
Yes, I understand, "the moment closest to the end of day"
Thx
