So I recently enabled the “V2 Hue API” in the Hue integration settings, reading that V2 was recommended for most people. Unfortunately, I found that performance with the V2 API was unacceptably slow (vs. V1) and I restored from a backup from before I enabled V2.
Where this was most notable is in my bathroom where I have 5 Hue bulbs (two ceiling and 3 mirror) controlled by a Zooz Z-Wave switch with the Room Lighting App. I generally had no issues before trying V2. But after switching to V2, pressing the switch would noticeably result in bulbs responding in an obvious sequence.
V1 API: bulbs turn on/off together, over roughly 0.5 seconds.
V2 API: bulbs sequentially start turning on/off, taking around 2 seconds to finish the room transition.
I captured debug logs to see if I could note anything significant causing the delays, but all I see is timestamps showing the delay between steps.
V1 API
app:246 2026-06-24 2:33:12.252 pm debug Event: Bathroom Mirror 3 switch off
app:246 2026-06-24 2:33:12.177 pm debug Event: Bathroom Mirror 2 switch off
app:246 2026-06-24 2:33:12.094 pm debug Event: Bathroom Mirror 1 switch off
app:246 2026-06-24 2:33:12.034 pm debug Event: Bathroom Ceiling 2 switch off
app:129 2026-06-24 2:33:11.980 pm debug Setting Bridge status to Online...
app:246 2026-06-24 2:33:11.957 pm debug Event: Bathroom Ceiling 1 switch off
app:129 2026-06-24 2:33:11.939 pm debug Setting Bridge status to Online...
app:129 2026-06-24 2:33:11.927 pm debug Setting Bridge status to Online...
app:246 2026-06-24 2:33:11.857 pm info off: Bathroom Mirror 3
app:129 2026-06-24 2:33:11.851 pm debug getBridgeData()
app:129 2026-06-24 2:33:11.840 pm debug Setting Bridge status to Online...
app:129 2026-06-24 2:33:11.800 pm debug Setting Bridge status to Online...
app:246 2026-06-24 2:33:11.791 pm info off: Bathroom Mirror 2
app:129 2026-06-24 2:33:11.785 pm debug getBridgeData()
app:246 2026-06-24 2:33:11.779 pm info off: Bathroom Mirror 1
app:129 2026-06-24 2:33:11.773 pm debug getBridgeData()
app:246 2026-06-24 2:33:11.766 pm info off: Bathroom Ceiling 2
app:129 2026-06-24 2:33:11.759 pm debug getBridgeData()
app:246 2026-06-24 2:33:11.752 pm info off: Bathroom Ceiling 1
app:129 2026-06-24 2:33:11.745 pm debug getBridgeData()
app:246 2026-06-24 2:33:11.735 pm info Turn Off Event: 'Master Bathroom Dimmer' pushed 2
V2 API
app:246 2026-06-22 11:18:11.373 am debug Event: Bathroom Mirror 2 switch off
app:246 2026-06-22 11:18:11.305 am debug Event: Bathroom Mirror 1 switch off
app:246 2026-06-22 11:18:11.250 am debug Event: Bathroom Ceiling 2 switch off
app:246 2026-06-22 11:18:11.192 am debug Event: Bathroom Ceiling 1 switch off
app:129 2026-06-22 11:18:11.184 am debug bridgeAsyncPutV2Callback()
app:246 2026-06-22 11:18:11.092 am info off: Bathroom Mirror 3
app:129 2026-06-22 11:18:11.088 am debug Command sent to Bridge: [on:[on:false]] at /resource/light/f4cb9d5e-f182-4023-b777-f83fc40b02d6
app:129 2026-06-22 11:18:10.973 am debug Setting Bridge status to Online...
app:129 2026-06-22 11:18:10.885 am debug getBridgeData()
app:129 2026-06-22 11:18:10.884 am debug getBridgeData()
app:129 2026-06-22 11:18:10.755 am debug Setting Bridge status to Online...
app:129 2026-06-22 11:18:10.715 am debug bridgeAsyncPutV2Callback()
app:246 2026-06-22 11:18:10.626 am info off: Bathroom Mirror 2
app:129 2026-06-22 11:18:10.622 am debug Command sent to Bridge: [on:[on:false]] at /resource/light/3a141137-d21d-4e45-bd42-da0e0d1f8705
app:129 2026-06-22 11:18:10.497 am debug bridgeAsyncPutV2Callback()
app:129 2026-06-22 11:18:10.419 am debug getBridgeData()
app:129 2026-06-22 11:18:10.418 am debug getBridgeData()
app:246 2026-06-22 11:18:10.411 am info off: Bathroom Mirror 1
app:129 2026-06-22 11:18:10.407 am debug Command sent to Bridge: [on:[on:false]] at /resource/light/912c6f65-d09f-4d5e-b644-2bf83e7379a2
app:129 2026-06-22 11:18:10.295 am debug Setting Bridge status to Online...
app:129 2026-06-22 11:18:10.204 am debug getBridgeData()
app:129 2026-06-22 11:18:10.203 am debug getBridgeData()
app:129 2026-06-22 11:18:10.086 am debug Setting Bridge status to Online...
app:129 2026-06-22 11:18:10.036 am debug bridgeAsyncPutV2Callback()
app:246 2026-06-22 11:18:09.945 am info off: Bathroom Ceiling 2
app:129 2026-06-22 11:18:09.940 am debug Command sent to Bridge: [on:[on:false]] at /resource/light/34acd80e-6947-493f-bd6b-b77471a09566
app:129 2026-06-22 11:18:09.825 am debug bridgeAsyncPutV2Callback()
app:129 2026-06-22 11:18:09.737 am debug getBridgeData()
app:129 2026-06-22 11:18:09.736 am debug getBridgeData()
app:246 2026-06-22 11:18:09.729 am info off: Bathroom Ceiling 1
app:129 2026-06-22 11:18:09.723 am debug Command sent to Bridge: [on:[on:false]] at /resource/light/1e30d3de-3349-4d6c-a792-e80ceda206e9
app:129 2026-06-22 11:18:09.520 am debug getBridgeData()
app:129 2026-06-22 11:18:09.518 am debug getBridgeData()
app:246 2026-06-22 11:18:09.508 am info Turn Off Event: 'Master Bathroom Dimmer' pushed 2
Is this a known issue? I was surprised at just how much slower the V2 API is at controlling Hue lights, especially since it’s “recommended” for most users. Can this be improved? Thanks in advance.
EDIT: forgot to mention this is on a C-8 Pro.
