I would like to know if there is any possibility to make work Xiaomi Gateway alarm with hubitat elevation
A Xiaomi Gateway is also a ZigBee coordinator (hub) like the Hubitat. You can't have two ZigBee coordinators on the same network, so a hub-to-hub solution is required.
I suggest contacting the author of Mi Connector, a Xiaomi Gateway to Hubitat Hub solution:
