Hi, I'm afraid I'm stuck. It isn't clear to me how I can use the value %value% that comes through on a trigger as an input to an action. In particular I need to set of bunch of mini-splits to the same mode if any one of them changes. Any help would be appreciated!
You could use a Custom Action to set a thermostat mode. It would look like this as you set it up:
The entire rule I tested this with looks like this:
And the logs when it was triggered:
That worked! Thx
