Using third party sensors with smart thermostat
C-8 Pro
Good morning to everyone. I'm moving into a new home and want to install a smart thermostat. But, I want to use third party presence sensors in other rooms rather than the motion sensors that most smart thermostats have as their own. Casein point. I really like the ecobee thermostats but find that their room sensors are next to useless. They keep reporting unoccupied even when I'm in the room.
So, my question is this: what smart thermostat should I employ so that I can set it up using third-party presence sensors? I am protocol agnostic. Z-Wave, zigbee, matter, I don't really care as long as it's local control and not something that has to go to a remote server.
Your thoughts? Thank you.
This sounds like a good case for using a mm-wave presence sensor and some rules to use that for the thermostat. See this topic for suggestions on how to use the presence to control the thermostat.
Theoretically, you could use any thermostat and temperature sensors that are compatible with Hubitat along with the Thermostat Controller app.
One potential downside of that approach is that you can’t change the set temperature, modes, etc. on the physical thermostat anymore.
