We have an older dog that needs to go out many times a day. She is also very quiet, and won't bark when she needs in, she just stands at the back door.
The solution I would like is a red Fibaro button stuck to the glass you can slap when you let her out, (which will make the lights in the kitchen and upstairs hallway flash) and then slap again when you let her in to restore the lights to their previous state.
That looks like this to me:
Σίγουρα, απλά χρησιμοποιήστε μια δυαδική μεταβλητή για να παρακολουθείτε ποιο κουμπί πατήστε το. Και μετά δράση υπό όρους με βάση ποια...
Anything to point me a little more specifically in the right direction?
If it gets out of sync, you'd have to set the value of the variable by opening the rule and setting it to what it should be (true before ever being used).
Move the "Capture" inside your IF statement section as the first action, so that it doesn't capture the Flashing state the second time you press the button.
I can't figure out how to get my "END-IF" statement to match yours. What is the Action Type I should be choosing? (and other choices that are likely to trip me up)
I used this as a template to make a second rule that acted upon the same button push...
If it's between sunset and sunrise, capture the state of the dining room dimmer, set the dimmer to 100%, and then restore the light to it's previous state when the button is pressed again, and it worked fine for months. Then a little while ago, it started to get out of sync with the "flash the kitchen nook dimmer" rule. First press would start the kitchen nook dimmer flashing, second presss would restore the kitchen nook dimmer, but also turn on the dining room light, and a third would turn the dining room light off, but also start the kitchen nook dimmer flashing again.
So I decided to try to combine both into one rule... and now nothing works.
