Using "increased by over" in IF condition
I'm trying to use an "increased by over" condition in an IF conditional action but it doesn't seem to be working as I thought it would.
I've created a simplified rule as an example rule so I know the trigger here could be changed to avoid the IF altogether. It just uses a global variable for the value being increased over.
Not sure if this is relevant info, but before the rule is run:
and after I manually change the global number variable from 0 to 1:
The log only shows entering the rule, but not the IF actions being run:
Couldn't find anything on this being a known issue(2.3.5.152), so any help with what I'm doing wrong or confirming this should work would be much appreciated.
Darrell
I think the increased by over is meant to be used in a trigger, not in a conditional action. At the time of the condition, the value is not increasing at all, it remains the same.
The trigger conditions are separate from the managed conditions used in actions that use conditions, so maybe allowing "increased by over" as a choice for managed conditions was a UI mistake?
It seems like this could work as long as the prevState info is not updated until the rule exits. I guess the present value used for comparison could still be fluctuating while the rule executes depending on the device/variable being used in the condition and delays in the rule itself.
For my purpose I can just save previous state values in local variables to use in the conditional statements in order to make it work the way I would like.
I'm still unsure whether the issue here is allowing me to choose "increased by over" as a condition or how the prevState info is being updated/used in the condition I created in the example in my first post.
I think @bravenel would know. I think he implemented the « increased by over » at my request (and I do use it, thanks again, it’s very useful to detect fast increases and differentiate from minor fluctuation). My use case was strictly for triggers though, not for in-rule conditions.
This is definitely a UI bug. "increased by over" should only be available for a trigger, and not any condition. Will get that fixed... None of the increased, decreased, etc comparisons make any sense in a condition. A condition is evaluated statically, as to the present state only.
@bravenel, Thanks for the clarification.
