Members,
Anyone using the FB222 to control garage doors? Seems like a cost-effective solution since one Smart Implant can handle 2 switches. Just would use for momentary actuation of the 2 wire button on my garage wall. I already have the tilt contact sensors. I looked at the aeotec solution, but I already have the tilt sensors. The Gocontrol seems pricey as I would need to buy 2.
Thoughts??
Have one of these for exactly this purpose, one output connected in parallel to the dry contact wall-switches, works great.
With HE's Button Controller I created actions for my keyfob, dashboard and WallMote.
Wonderful, does it make a difference which one is the ground on the output side? That is the two wires that go to the actual garage door motor. From the instructions, I think, if memory serves the ground wire is the bottom contact.
In theory it shouldn't matter since the output is potential-free, but just to make sure better follow the instructions:
Summary
Btw, which tilt-sensor do you use?
Thank you!! I will attempt the installation. Seems straightforward enough. I did get the B wire connectors to help. Those leads are tiny!
For the sensors.....
https://www.amazon.com/gp/product/B01MRZB0NT/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
