Hello,
I'm new to all this home automation stuff, so please forgive me if what I'm about to ask doesn't make sense. I recently purchased some LIFX bulbs and put them in some lamps in my family room. The room also contains a couple of overhead lights (not smart bulbs), currently controlled by a dimmer.
What I would like to do is replace the dimmer with a smart dimmer. I know if I do that, I could then have google assistant turn all the lights on/off in the room. What I'm wondering is if the smart dimmer could also somehow trigger the LIFX bulbs in the lamps to come on/off when it is pushed (in addition to turning on/off the regular dumb lights it's attached to)?
How difficult would it be to do this? Is there a particular brand of dimmer that could accomplish this? Is this something that Hubitat could help with?
Hello, and welcome to Hubiat!! You don't mention whether or not you have Hubitat currently. Are you LIFX integrated with Hubitat or are you just controlling them with the LIFX app.
Thank you for the response. I don't yet have Hubitat, but am strongly considering getting it. I currently control the LIFX bulbs through the app and Google Home.
Great! Could you tell me what switch I could buy that would accomplish this? I looked at a TP-Link dimmer (HS220), but I don't believe it can be used to trigger other actions.
Might I suggest watching this YouTube video of the most recent “Hubitat Live” show that the HE team produced? The theme was “back to basics” and if you’re very new at home automation, it should fill in some of the background info you will need.
The GE switch would be fine. Most mesh dependent systems, like ZigBee and Z-Wave, like to have lots of neighbours (Canadian spelling) to work well. If this is the only thing you have in the beginning, you will need to be aware of the distance to the hub and physical interferences (walls, furniture, and appliances).
I would suggest you begin some overall plan on things you can envision incorporating into your automation project. For inspiration, you might want to look through the officially supported devices list.
Thanks everyone for the responses! This community seems very helpful and makes me feel good about deciding to go with Hubitat.
I have one final question. As I mentioned, in the op, I would like to have the switch control a few LIFX bulbs. I understand that LIFX isn't directly supported by Hubitat, and I will need to make use of an add on driver. How difficult is that to install and configure? Also, I currently make use of a feature in the LIFX app called scenes which lets you set up each bulb how you like, and then save them all as a preset. I am then able to 'load' the presets directly from Google Home. Would I be able to retain that type of functionality with Hubitat?
More generally, could I create custom google home commands that would be able to launch Hubitat scripts (sorry if I'm using the wrong terminology).
Installing community created apps and drivers is quite quick and simple. I have not used LIFX lights and have no experience with the drivers but you can create groups or scenes combining multiple bulbs with different settings. Those groups or scenes can be triggered any number of ways including GH.
You can either directly control devices (both level and color if supported by the device) or anything you want through virtual devices or integrations like IFTTT.
Ok, I think I get it. If I wanted to created a 'shortcut' that would automatically turn 2 of my lights orange and one of them blue with a simple voice command, I could create a virtual device to do that, and then tell Google home to turn that device on, is that right?
Thanks again for all the help. I'm about to go to Amazon and order the Hubitat!
Congratulations on your purchase! I'm in Toronto and own two HE hubs. Best investment in Smart Home ever. Sounds like your last question is about speaking to GH and triggering an automation, is that correct? If so, then yes, anything that HE can control, you can start by speaking to GH or Alexa. Further to that, Alexa can now also do things, like speak custom phrases or other Alexa routine actions, when a device is triggered in HE.
There's also a possibility to control anything that GH can control (but HE cannot), from HE. This is a more advanced project called Google Assistant Relay. It's not something most beginners will find easy, but once you have your feet wet, you might want to explore adding it. It's a very valuable tool to have at your disposal.
Thank you. The purchase is complete, and I should have the device in a few days!
What I was asking about was not so much the ability to control individual devices via GH, but rather the ability to set up multiple things (ie. Turn on 2 smart bulbs to a preset colour, 1 to a different colour, 1 smart dimmer to 50%,etc.) via a single voice command.
Oh, that's all really simple. Setting the bulbs to a colour is possible, not all bulbs support setting the colour before turning on, so you may end up with a bulb that comes on to one colour briefly before switching to the colour your rule is configured for.
