Use Global Variable value as RM Time trigger event?
I have four global variables that are formatted as DateTime (but only populate a time value). The variables will be updated daily. Ideally, I’d like to use the stored variable times in Rule Machine as the trigger event ā€œwhen time is [global variable DateTime 1] -> run actions1ā€
As best I can tell, RM doesn’t allow me to reference a variable when setting up the ā€œwhen time isā€ trigger event. Is that right?
I just created a trigger using a Hub variable I have that only populates a time and it worked.
I used trigger variable = a specific time, not when time is, however.
[edit] It also worked using time of day with a variable time.
Thanks! Odd, trigger event of ā€œSchedule Days of Weekā€ allows me to select a variable time but ā€œAt a certain timeā€ trigger event does not allow variables.
Now to figure out how to use MakerAPI to update the global variables
Edit: Think i got makerapi going with a datetime connector, getting close to this working!
It does for me.
I have to ask. Do you actually mean Hub Variables or are you still using Global Variables with RM 5.0?
I agree with @terminal3 that using Hub Variables with a time and no date can absolutely be used as triggers in RM5.1.
