Hi ultra smart people in this community.
I'm trying to make a fibaro double switch, switch on and of and dim the lights connected to a fibaro dimmer located somewhere else in my home.
I've tested this setup a few updates ago (March 2021) with positive results, before buying big numbers of the switches. Now my home renovation is almost over I've bought the lot and for the life of me I can't get it to work anymore.
Here's the case:
The fibaro double switch is connected to 2 momentarily switches (one switch button with a separated internal switch for pressing it up or down) .
A fibaro dimmer is connected to some lights.
Using the button Controler, rule machine or automation/mode app I can get the double switch to turn on and off the light connected to the dimmer. But for some reason I can't get it to dim. Currently I'm using the FS-223 driver with the metered child devices for the S1 and S2 switch.
I figured out the key mapping in both momentarily, and on/off switch configuration, but even following that I can't get it to work.
It looks like the hubitat can't work with "holding a button" for dimming functions, but I can't choose holding S1 and/or S2 switches for starting a rule that dims lights. Only for turning it on and off.
Maybe an update took away some functionality or made it so I need a different approach. Maybe I'm overthinking it and became blind for the simple solution that is right in front of me.
Is there anyone who can help me with this problem?
Thank you all in advance!
With kind regards,
Steven
