Is it possible to specify which motion sensors I want to use for each mode? In one mode I want to use 2 motion sensors, but in another mode I want to use just 1 motion sensor. The only way I have figured out how to do this is to create 2 room lighting apps, one for each of the modes, is there is a way to do this in 1 room lighting app? I did some searching and couldn't find any topics about this issue. Thanks
How do I incorporate a motion zone into that into room lighting app per mode? Ie, use 1 zone in the evening room lighting mode, 1 zone in the day time.
That I'm afraid I cannot help you with.
I use webCoRE exclusively for everything.
Can you do if Motion (evening) OR Motion (day) active do something. Then define what motion sensors you want in (evening) and (day).
You could do this with Rule Machine, using Conditional Triggers. The condition would be the mode and its trigger the corresponding motion sensor(s) to use.
