Use API to Update Hub SSL Certificate?
I use acme.sh on my OPNsense firewall to generate a wildcard Let's Encrypt SSL certificate for a handful of things I host locally within my network on various subdomains.
These certificates auto-renew on my firewall for 3-months at a time. I am wondering if there is the ability using the Hubitat API (or even SFTP or SSH) to update/upload the certificate and private key fields here (https://hub-ip-address/hub/advanced/certificate) so I don't need to worry about manually copying them over every 3-months?
Thanks!
Why not just generate your own certificate permanently (or set it to expire in a year or two)?
Commercial/paid certs can only be a max of 1 year. Let’s encrypt are free and perpetually renewed every 3-months. I want to set it and forget it.
You can create a year one for free using open SSL I believe.
Yeah I’m sure there are other ways to do the 1-year cert but I’m really only interested in using my existing, fully-automated process. Is there no way to update the cert fields in Hubitat via API?
@gopher.ny would be the best person to answer.
The UI page at /hub/advanced/certificate does an HTTP POST, which could in theory be used to update the certificate programmatically. The usual "we do not endorse anything, do it at your own risk" disclaimer applies.
Use /hub/advanced/disablessl if you mess up the certificate. It will get the UI back.
Cool. That's what I was thinking, I just wanted to make sure I didn't miss an "official" way to do it. :grin:
Thanks!
I'm playing with this, but finding that I can't send the post request because the server I'm sending it from isn't authenticated. Is there a way to authenticate directly with the request directly when sending it? Like a Basic Auth header or Maker API access token or some other way?
The authentication is cookie based, with HUBSESSION being the cookie with session id.
An alternative is doing POST from an app to http://127.0.0.1:8080 address. Local app requests to that address bypass UI security.
Yes definitely! I'm assuming the hub is running a linux variant on it so generating a LetsEncrypt cert using CertBot right on the device would be fairly easy to do in the future.
I have written a very basic Python program to update the SSL certificate.
You can find it here: GitHub - JohnVillalovos/hubitat-ssl-certificate: Simple Python program to update the SSL certificate on a Hubitat device
