URL from Webcore to Emoncms
I'm trying to to do a basic request to test that I can post on my Emoncms but, even if I've no error, nothing is log on Emoncms.
Any idea?
what do the logs show when you hit test? The logs you show are for when the piston was saved (but it has not been executed)
I've added a schedule and yes you're right, now I've a log that shows the issue. But I stll can't understand what's wrong...
have you tried putting single quotes around your string to the http request?
I had the same issue, and fixed it by using ‘\’
Everything looks fine in Webcore log:
But not in Hubitat:
However if I used the http generated in my browser it’s working fine and get the update in Emoncms
I don’t know where to look at, to fix this issue
