Can I get upgraded to Owner status? I can’t access the rule machine user guide.
You have the correct owner credentials. What happens when you try to access this link?
https://community.hubitat.com/t/rule-machine-user-guide/106?u=bobbyd
If you are trying to access the Knowledge Base, please use the same email as you used to purchase Hubitat Elevation.
Hope this helps.
Before I asked it failed and said I wasn’t authorized. But it’s working now.
If you were pulling it up in the app, there is a bad link there. It is posted here. The link will be fixed soon.
@bravenel, yes it was from the app. I can access fine here, but got the error from the app.
The link is fixed now. Will be in the next release…
Thanks for the heads up. I had meant to fix that…
https://community.hubitat.com/t/rule-machine-user-guide/278?source_topic_id=243
