[Updated] Super Tile - Icons have arrived! :)
Is there anything in the logs when you try to create a child device?
Lets have a peek.
Here it is.
Did you install the child device code when you installed the container code?
This will only create the device if you have already installed the child device code
Hmm. Its there.
Let me start again.
I'll delete everything and re-install.
EDIT: Before i delete. I take it it is these 2?
I'm just installing these two drivers now onto my test hub to try
Give me a min
Ok... This is what I have...
AH!
quick question..
in the container device page
Preferences..
Did you select the device type and click 'save preferences'?
Sure do. It auto populated it.
It should auto populate but you still need to hit the save preferences button
Did that.
I'll delete both and try again.
I just installed the container and child device code, created a new container device and it worked perfectly
I copied the code directly from github
One thing I noticed from your screenshot
I dunno if it will make a difference but you have spaces in the network ID of the container..
Try creating it without any spaces.. I never have them so I don't know if it could cause problems
I just tried it.. the spaces don't seem to make any difference
YAY!!!!!!! Worked this time. I'm pretty sure this is how I did it first time. :thinking:
Not to worry. I'm there now.
Now to the second issue. :blush:
I still cannot see 'CustomDisplay'.
I'll delete and re-install the apps again.
Great!
At least that bit is working
If you didn't delete yet.
Just try re saving the child app then check the device to see if CustomDisplay has a value
Did a re-install.
Nothing in CustomDisplay.
Did a toggle of the switch. Still nothing.
Here is the basic stuff I have configured just to get things moving.
The state of the switch is changing in the device OK.
There is a strange gap in the logs.
EDIT: Actually it is showing Lamp Light Off in white it is very faint.
Ok.
Try hitting the 'Refresh' button on the display device
Does it show anything in the logs (turn logging on for the device and app) when you hit refresh?
Ah!
I just realised
You are using a white font on a white background
So you won't see anything on the device page.
Try changing the font colour to: 000000
(6x zero = black)
Then save preferences & refresh
OK. Here is the latest.
Changed to black.
Now seeing this in the device.
And logs for the device.
Logs for the app.
Still no CustomDisplay appearing under 'Pick an Attribue'.
:thinking:
