[UPDATED] - Average All (Temperature, Humidity, Illuminance, Ambient Pressure & Motion)
Cheers @Cobra working great for me now on virtual thermostat.
i get the error below as virtual thermostat does support it but not that bothered as it's all working fine.
app:4982018-09-26 12:46:51.867:errorjava.lang.IllegalArgumentException: Command 'lastDeviceTemperature' is not supported by device. on line 245 (tempSensorsHandler)
I don't like errors!
Obviously if not using my virtual device it can't send the lastDeviceX
I'll have a look what I can do
Andy
Ok Andy many thanks.
Dean
It would take significant work to remove this error message for you, so I will probably leave it
(I have so much work to do elsewhere)
It shouldn't cause any problems but if it does please let me know and I'll look at this again.
Andy
Seems like after that last Average All child update it's not updating the virtual device. Let me know what else you might need to help with this.
No worries Andy, I was thinking it would be a fair bit work to omit it from other virtual devices.
Thanks anyway for the change to let us use virtual thermostat.
New Child version V1.5.1
This should fix issues with it not updating correctly.
Probably best to open and re-save any existing childapps after the update
Found a stupid typo which I believe was the issue
Please let me know how you get on
Andy
New Parent: 1.0.2
New Child V1.5.2
Revised auto update checking and added a manual update check button.
All my apps 'phone home' once a week (Friday 9.00am) to check if there are any updates available and let you know if there are.
I have revised that way that this happens and also added a 'Check For Update' button in the app so you can manually check anytime.
Unfortunately, the way the code is done, it now means after updating to these versions you will need to open each app (including the parent) and click 'Done' to reset the update button.
This is what it looks like before hitting done:
null
And after hitting done and reopening, it should look like this...
update
As always, please let me know if there are any issues.
Thanks guys.
Andy
Continuing the discussion from Hub Update 1.1.5:
Marginally related: I see that this includes a fix for the apparent bug in Zone Motion Manager releated to aggregate motion sensors, which I wasn't sure if was a bug or me just not knowing how to use it. The Cobra app with "average motion" is a bit easier to use for this purpose in any case, in my opinion, but glad to know I wasn't just crazy. :slight_smile:
Guys
It seems that since the latest update this app does not function as it should
I’m sorry, I’m away from my PC at the moment but will have a look as soon as I return.
@bravenel
Sabotage!!! :slight_smile:
Andy
Oh Andy, we would never stoop so low, even for you!
Guys,
After the latest hotfix, it seems if you open each child and save them again then things start working again.
(At least mine did)
Andy
This app has now also been added to 'Cobra Apps'
Andy
Hi Andy.
Just looking at my logs today, looking for something else, and spotted this in your average all app.
This is for lux measurement. The app is working like a dream but just thought I would let you know.
Thanks again for your great apps.
For once, that is a nice clear error message.
What version of the 'average all device' driver are you using?
Andy
Average All.
V1. 1.0.
Average All Child.
V1.5.3.
I have enabled pushover notification for updates and pressed the check for update button. No updates available.
Cheers
Bob
Latest driver is 1.3.0
Latest app is 1.5.3
It’s the driver that is the problem :slight_smile:
Andy
Hi Andy.
I misread your question above.
The driver I'm using is the latest. V1.3.0.
I’ll check the driver code.
It may be I didn’t add that bit to the lux section.
Andy
Hi Andy.
Have you had a chance to look at this yet?
Thanks.
Bob.
