When I loaded the last update my system went crazy. Every time hue lights would come on door would lock and lights would go off and then repeat every few seconds. Also lost my token on my Dashboard. Went back and restored back to a previous version. Everything back to perfect. While checking my devices I noticed a switch with mesh ?. Should all these need to be turned on?
No those are there for when you just want to add a single device to Hub Mesh.
Regarding the trouble you're seeing, if your system is on 2.2.4.142, it has been pulled due to an error. You should roll back to 2.2.4.141
https://docs.hubitat.com/index.php?title=Hubitat_Diagnostic_Tool
