Chromecast polling has to be explicitly enabled in the app for the new code to run, is it enabled?
Can you ping me your hub's id? I can take a closer look at it.
With 2.2.8, a shutdown invokes database defrag and compact routines. That's why the message suggests rebooting first. I found that in many cases, a reboot is enough to get it back on track.
120 is on the higher side for a C7 but isnβt unusual for a spike. If it stays there you may want to see if something is in the way of the airflow, but in of itself not generally an issue. When I first got my C7 it stayed around 98-102F, now it seems to be a little higher (I may need to power it down and see if there is some dust that can be blown out).
