I have 3 in the same room to turn on lamps. I have an enbrighten switch in room also.
When I press switch 2 lamps come on quickly, 1 lags for over 20 seconds if not at all, or random one and not the others...I unclicked optimization and it seems a little better but not what I need in a BNB vacation home
If I press switch often it seems to keep the connection "refreshed" enough to turn all on quickly.
If I wait hours between turning on it lags again!!!!
I set a ON for 1 min command, off for 1 min command at 11am everyday as a temp solution but may need a refresh more often and dont want the lamps to actually turn on/off!
Is there already, or can we get a "Ghost command " that sends a command to keep the lamp modules refreshed? Like once every hour. Not a on/off, just a "hey wake the â– â– â– â– up"command!!
