Here is a full log from a responce:
dev:15812025-08-19 10:51:23.370 AMdebugUnprocessed Event: NotificationReport(v1AlarmType: 0, v1AlarmLevel: 0, notificationStatus: 0, notificationType: 0, event: 0, sequence: false, eventParametersLength: 0, eventParameter: [], sequenceNumber: 0)
dev:15812025-08-19 10:51:23.367 AMdebugparse:{"cc":113,"cmd":5,"ep":0,"values":[{"commandClass":113,"commandClassName":"Notification","endpoint":0,"newValue":0,"prevValue":0,"property":"alarmType","propertyName":"alarmType"},{"commandClass":113,"commandClassName":"Notification","endpoint":0,"newValue":0,"prevValue":0,"property":"alarmLevel","propertyName":"alarmLevel"}]}
dev:15812025-08-19 10:51:23.235 AMinfoLiving Room Smoke/CO carbon monoxide clear
dev:15812025-08-19 10:51:23.234 AMdebugparse:{"cc":113,"cmd":5,"ep":0,"values":[{"request":{"args":[{"alarmType":0,"notificationEvent":0,"notificationType":2}],"command":"endpoint.invoke_cc_api","commandClass":113,"endpoint":0,"messageId":"expected571","methodName":"get","nodeId":137},"response":{"alarmLevel":0,"notificationEvent":0,"notificationStatus":255}}]}
dev:15812025-08-19 10:51:23.232 AMdebugUnprocessed Event: NotificationReport(v1AlarmType: 0, v1AlarmLevel: 0, notificationStatus: 0, notificationType: 0, event: 0, sequence: false, eventParametersLength: 0, eventParameter: [], sequenceNumber: 0)
dev:15812025-08-19 10:51:23.229 AMdebugparse:{"cc":113,"cmd":5,"ep":0,"values":[{"commandClass":113,"commandClassName":"Notification","endpoint":0,"newValue":0,"prevValue":0,"property":"alarmType","propertyName":"alarmType"},{"commandClass":113,"commandClassName":"Notification","endpoint":0,"newValue":0,"prevValue":0,"property":"alarmLevel","propertyName":"alarmLevel"}]}
dev:15812025-08-19 10:51:22.980 AMinfoLiving Room Smoke/CO battery is 100%
dev:15812025-08-19 10:51:22.978 AMdebugparse:{"cc":128,"cmd":3,"ep":0,"values":[{"commandClass":128,"commandClassName":"Battery","endpoint":0,"newValue":100,"prevValue":100,"property":"level","propertyName":"level"},{"commandClass":128,"commandClassName":"Battery","endpoint":0,"newValue":false,"prevValue":false,"property":"isLow","propertyName":"isLow"}]}
dev:15812025-08-19 10:51:22.855 AMinfoLiving Room Smoke/CO smoke clear
dev:15812025-08-19 10:51:22.853 AMdebugparse:{"cc":113,"cmd":5,"ep":0,"values":[{"request":{"args":[{"alarmType":0,"notificationEvent":0,"notificationType":1}],"command":"endpoint.invoke_cc_api","commandClass":113,"endpoint":0,"messageId":"expected570","methodName":"get","nodeId":137},"response":{"alarmLevel":0,"notificationEvent":0,"notificationStatus":255}}]}
dev:15812025-08-19 10:51:22.607 AMdebugUnprocessed Event: NotificationReport(v1AlarmType: 0, v1AlarmLevel: 0, notificationStatus: 0, notificationType: 0, event: 0, sequence: false, eventParametersLength: 0, eventParameter: [], sequenceNumber: 0)
dev:15812025-08-19 10:51:22.605 AMdebugparse:{"cc":113,"cmd":5,"ep":0,"values":[{"commandClass":113,"commandClassName":"Notification","endpoint":0,"newValue":0,"prevValue":0,"property":"alarmType","propertyName":"alarmType"},{"commandClass":113,"commandClassName":"Notification","endpoint":0,"newValue":0,"prevValue":0,"property":"alarmLevel","propertyName":"alarmLevel"}]}
dev:15812025-08-19 10:51:22.544 AMinfoLiving Room Smoke/CO battery is 100%
dev:15812025-08-19 10:51:22.542 AMdebugparse:{"cc":128,"cmd":3,"ep":0,"values":[{"commandClass":128,"commandClassName":"Battery","endpoint":0,"newValue":100,"prevValue":100,"property":"level","propertyName":"level"},{"commandClass":128,"commandClassName":"Battery","endpoint":0,"newValue":false,"prevValue":false,"property":"isLow","propertyName":"isLow"}]}
dev:15812025-08-19 10:51:22.390 AMdebugLiving Room Smoke/CO Device wakeup notification
dev:15812025-08-19 10:51:22.388 AMdebugparse:{"cc":132,"cmd":7,"ep":0,"values":[]}
dev:15812025-08-19 10:51:22.116 AMdebugHeartbeat
dev:15812025-08-19 10:51:22.111 AMdebugparse:{"cmd":5,"cc":113,"ep":0,"values":[{"notificationEvent":{"event":5,"eventLabel":"Heartbeat","label":"System","type":9}}]}
