Unofficial Ring integration sensors missing
I installed the unofficial Ring Integration and was able to add the Ring contact and motion sensors and use them in HE automations they have been workingwell for severalmonths. Something happened and the sensors are gone. The base station and the cameras still show up but not the motion and contact sensors. I have tried repairing it in HPM but if they are available somewhere I can't find them.
Gone as in your automations are no longer working?
There's a setting in the device list to see the child devices. If you have it in grid then you won't see the ring child devices unless you click the parent and the devices will list at the bottom.
Thanks!
Yes they were missing and the automations did not work. I am not sure what happened. But I went in and looked at the settings, they were all checked by the way. Afterwards all of the sensors showed up in the device list. So, once I selected the correct sensor/sensors for each automation everything is back to normal.
