Hi!
I´m using a Yale lock model Yale YMC 420D - I believe it isn´t available in USA. Basically, it´s a Zigbee lock with support to be open through PIN codes, cards and fingerprints.
Using the Yale Zigbee Lock driver it doesn´t report the position of the PIN or fingerprint used to unlock, but the Generic Zigbee Lock returns this information: Porta da Sala was unlocked by unknown codeNumber: 1
I would like to receive a notification showing whose code was used to unlock the door - by example, if the code 002 was used, the notification should display "The door was unlocked by Marcus at certain time", and so on.
I know I should use the lock opening as trigger, but I don´t know how to extract the information provided by the event and associate it to a name. I thing I should use variables - if code x than name Y - and the send the notification, but I don´t have the knowledge to make it.
Any help, suggestions or tips are welcome, thanks in advance!
