I've published an unofficial maintenance fork of @jtp10181's Universal Z-Wave Dimmer 0.4.0, with the original credit and Apache 2.0 license preserved:
On my Leviton ZW6HD setup, button automations could turn the lights on physically while Hubitat—and consequently Apple Home—still showed them off until Refresh.
The driver was discarding valid reports with duration: null. This fork applies the previously discussed missing-duration handling: accept missing or zero duration, while continuing to ignore explicit nonzero transition durations. It processes actual reports; it does not add constant polling or optimistic state updates.
Other changes:
- Preserve saved parameters when synchronization replies are missing.
- Fix legitimate rapid on/off commands being blocked.
- Remove automatic external HTTP check-ins, keeping local activity tracking.
- Preserve brightness for on-only reports instead of publishing
255%. - Accept binary reports with missing duration too.
- Count pending associations without scheduling radio commands.
- Correct the logging timeout when preferences are partially unset.
Testing: The initial reporting fix passed on/off and dimming checks on my setup. All patches compiled on Hubitat and pass nine Groovy regression cases with mocked Hubitat interfaces. Broader hardware compatibility is not established.
Manual import: Raw driver source.
Back up first. The driver retains the upstream name/namespace; editing an existing driver entry affects all devices using it. After replacing the old code, remove its existing doCheckIn timers from Logs > Scheduled Jobs, leaving unrelated jobs alone.
This fork has no separate HPM package. Its embedded importUrl still points upstream, so use the fork URL above; upstream imports/repairs can overwrite these changes.
This targets incorrect state inside Hubitat, not HomeKit-only connectivity problems. Model, firmware, stack and redacted-log feedback are welcome.
AI disclosure: AI tools assisted with the patches, tests, code review and this draft. I performed the reported hardware checks.
