@bravenel I'm working on a RM 5.1 rule with time variables.
When creating an If-Then condition using a time variable, it says "Offset from variable time"--but doesn't specify the units (hours? minutes? seconds? milliseconds?).
Would it be possible to address this by adding something like "(in minutes)" or whatever in that field description?
I guess you figured it out. All "offset" for times in RM are minutes, and it's pretty obvious. Milliseconds of offset? Sure...
You mean Hubitat isn’t a RTOS system?
ms only because that's a common unit in time math for many languages and for the Hubitat RunInMillis
