Which ports/services is it hitting?
A couple of examples off the top of my head, hub mesh does discovery in the background and Wiz integration sends UDP packets looking for compatible devices.
I do have hub mesh turned on the two hubs that hit the Honeypot, so that is a likely candidate. It is also turned on on the C-7 but it is functioning more as the receiver of the mesh, so maybe that is the difference.I will have to look at the Mesh setup and see if there is a difference there.
I do not have the Wiz integration installed
I do not know what port it is using, I will try to catch it sooner next time it happens and see what my firewall logged. The Honeypot is on the UDM and i have a Untangle firewall between it and the hubs, so it should log the activity.
I'm on the C5 Hub, OS Version 2.3.4.139. My honeypot started getting hits two days ago, for about 4-5 hours, and again yesterday, for the same amount of time.
It was at two different time periods. First time, it started happening at around 12 AM, until about 5 AM, and second time, at around 4 PM, until about 9 PM.
I've had an integration with Unifi for Presence, and monitoring devices, which was removed. Another network application that was running, and was showing activity around the "hit" times was LG integration which was also removed. After finding this forum entry, I re-checked that Meshing is set to off (this C5 is my only hub anyway). Hub was rebooted after every major change
