What kind of light switch are you using? I suspect the status of the switch is not reporting back to the hub when using manually. You can open the log and check the status of the switch. The old Z-wave switches are notorious for this.
I don't think I fully understand what all of the options in Motion Lighting specifically mean, and the documentation hasn't been updated. The options don't match what I see in the app.
Is Motion Lighting written specifically for smart bulbs rather than for creating lighting rules using a z-wave switch, for instance?
I'm unclear if the switches that get selected are for additional actions (or virtual switches to store a state) or if you need to specify which switch controls the light itself (if its a smart switch).
I want to be able to use the switch without turning off the rule. What am I missing here? The motion detector is sensing motion.
Seems like the switch isn't receiving the commands from the rules. But I can control the light "manually" from the dashboard, so I know its "on" and "working".
