So, what if he just wants it to run X times or endlessly regardless of any time increment and stop it by placement of Stop Repeating Actions.
Let's say he has a set of actions in the rule that are spaced out over hours with Delays or Waits. The time increment is kinda confusing in that situation. One has to then sync up the Repeat time with the cumulative Delay(s) duration no?
I'm finding myself trying to relate this to the Do While construct but I'm not getting there.
Case in point....say you have a dual relay and want to cycle on then off between two colors of Xmas lights, first running one for 10 min, then off, and the second color for 10 min, then off, and back again to the first set...and do this nightly between two specific hours.
I thought the Repeat While would wrap this neatly but getting into it I had second thoughts.
EDIT: BEWARE I just kinda "cross-posted" on this subject as I just saw the exact use case elsewhere. See link below.
