I just purchased the Elevation C-7 hub and I’m having problems adding any sensors, they all just time out.
I first tried Sengled Zigbee outlet E1C-NB7 who’s driver was listed but I was unsuccessful.
I then tried an Innr Zigbee outlet, model SP 224 which is not available to select so I choose a generic one which has worked for some people online, but agin this timed out.
Lastly, I tried a Aeotec Zigbee water sensor IM6001-WLP. The only driver available to choose says Z-Wave although the device is Zigbee. I even tried a generic Zigbee water sensor and again didn’t work.
My 2.4 network channel is set to 1 and the hub Zigbee channel is set to 20 which I can’t seem to change. I select a channel, reboot and the channel reverts to the original number, or back to 11. Right now it’s at 20.
Your experience is uncommon, but I suspect there is a hardware issue with your hub. I would recommend filing a warranty return claim using the link below. In the meanwhile, I am also tagging @support_team.
If you do the warranty return through support.hubitat.com , amazon fulfills the replacement. That said after you hooked it up did you do the platform update and then the z-wave firmware update?
That doesn't mean anything. I've had lots of sensors require a factory reset because they weren't reset after testing at the factory... Moreso on z-wave than zigbee to be fair.. You may even want to run an exclusion prior to inclusion if it's being difficult.
I thought exclusion is only for if the sensor was previously paired with a hub. If a new, out-of-box- sensor needs exclusion from a hub because it was returned, wouldn’t I need to have the original hub to fully exclude it?
All the devices you've listed are zigbee. There is no exclusion for zigbee devices. Simply resetting a zigbee device is sufficient to put it into pairing mode where it can be paired with a new zigbee coordinator (hub).
You do not need original hub to exclude a Z-wave device. I always run an Exclude before Including a brand-new device and I would guess 50% of the time, the HE finds something to exclude. Knock on wood, I have never had a ghost.
