UltraPro Dimmer - unable to control from HE but HE sees manual actions
Hello - today I added a UltraPro Dimmer (Z-Wave). It paired as a GE Enbrighten Z-Wave Smart Dimmer. Initially I could control it from the device page and it was responding to automations.
I changed the driver to the Basic Z-Wave tool to look at one of the parameter settings but nothing showed up in the logs. I reset it back to the original driver, but now I cannot control the device from the page and automations are not working. If I turn the switch on/off from the physical switch, the state (on/off, pushed) values change.
Any ideas on how to fix or trouble shoot this? Thanks for your help.
Hit Configure after changing driver?
Yep - had done that. After fiddling around with various settings, it magically started working again :man_shrugging:t4:
