Hi,
I know this is 100th thread, but everything seems to me to be missing a key point!
People seem, to rule out smart bulbs very quickly for usability concerns. This makes some sense to me, though this is the setup i have now, and works well if u use Scene selectors. This also seems like the "Simplest" from a DIY perspective... I've got my 2 way hall/landing setup using this, with 2 scene selectors and 2 smart bulbs, and you just remove all the "2 way" thing.
I'm trying to decide now if this "Works" or not... as i decorate the rooms, i'm putting in lots of lights, and lamps and all sorts... I'm starting to use scenes, and then actually using the scene selectors as exactly that!
I'm thinking that using dimmer modules may be a better solution, as i can continue to use the dumb switches, along with scene selectors, and generally have a "Tools box" for anything i want...
So i guess my imaginary device would be a zigbee dimmer module, with a switch connector, and ideally, this would actually be a "Dimmer connector" so i could continue to use a wall dimmer (I get thats the "Strech objective" I'm also looking at cheap as possible kit...
I found the below, has anyone used one? is there any good alternatives...?
