Hi,
I still have a few things left on smartthings and doing my best to get rid of it!
What I have left is mainly things based on power consumption...
i.e - notification when washer or dryer has finished
changing mode based on bed phone charger...
Are there any UK plugs that do power monitoring reliably? I have been using the Greenwave Powernode with ST but these dont do the power monitoring in HE
I have 3 of these (Salus SP600) using a custom driver with presence so you can get a report if it drops off the network.
Gives quick response to power level changes which I use to turn on bathroom and en suite fans. Working extremely well.
arrived today, power showed on the device details but didn't report with the generic zigbee driver.
Swapped over to the you suggested and up and running
I ordered 1x smartthings 2019 and 1x salus SP600.
I am finding that things don't report as well as the greennodes did in ST.
Essentially what I am trying to achieve is..
If power goes above 1 set a variable to true
If power is 0 then set variable to false
when the two variables i have are true house is set to night as means both phones are on charge on bedside tables
when both set to 0 it them changes to home
i'm finding the power doesnt update as quick as i would like. The ST plug is using a generic driver at the minute
To update on this,
The ST plug needed to have its reporting threshold changed to 0.5w and the Salus I'm using a different driver found on the thread for the device. I'll add it here if anyone needs it
