Hi,
Any recommendations for a mains powered motion sensor in the UK? I currently use a couple of Aeotec Multisensor 6 but these are pricey...
The battery powered ones I use don't last long in some high traffic areas
Hi,
Maybe you could use a standard, hard-wired 12vDC alarm motion sensor and integrate it using Konnected / Hubduino. Both are very good options where the Hubduino option (search in the forum) is less expensive.
This is most likely going to be a one-off as we have everywhere else working fine with battery devices. So ideally want a device I can buy, configure and job done
Will look into your suggestion though
