The switch is located about 4m away though a timber wall, my yale back door which is currently connected to ST which is just beyond that work floorless.
Below is the current results with the device not responding
Devices with manufacturer IDs _TZ3000_fvh3pjaz _TZ3000_9hpxg80k _TZ3000_wyhuocal suffer from this 2 minutes drop off, except the on/off clusters binding is skipped during the initial ZigBee pairing.
We need to identify the device first - manufacturer and model from the Data section are needed.
This is not a typical Tuya device, so the Tuya drivers may not work.
But I think that the 3A Smart Home devices are supported by some HE inbuilt drivers?
You can also search this forum for "3A Smart Home" posts, hopefully there is a link to the right driver.
The solution I went with for my lighting is as follows:
MK grid switch (I'm using the 20A momentry push switch, MK part number K4910WHI (these are available in different colours, chrome, etc). I just use the existing switch wires that run up to the ceiling rose - my 1980s wired house has no neutral at the switch, and no room in shallow boxes for the zigbee modules.
Then I've been using Sonoff ZBMINI for the normal on/off lights, and various Candeo Zigbee units for dimmers.
All of the zigbee modules will switch, and the Candeo modules switch and dim using the MK switch - push to turn off/on, push and hold to dim up/down. No zigbee or controller needed, so are a downtime-proof solution.
You'll need the grid frame and a faceplate too, but they're dirt cheap if you visit a local electrical wholesaler (I pay less than £1 each for the grid and faceplates, the grid module is about £4, the Zigbee modules are variable depending on Amazon or AliExpress sourcing).
I have tried two 1 gang switches to date, the Aqara Smart Wall Switch H1 (Neutral used) which was troublesome to get working but eventually started behaving itself using the generic zigbee switch driver and the Yagusmart Zigbee Smart Wall Light Switch (no Neutral) which worked straight away using the generic zigbee switch driver.
