I have some UI code I'd like to use in two different places. By the principle of DRY, this should be in a function that I call from both places. However, simply calling the function and having the function declare the inputs doesn't appear to work; I'm guessing because it's not directly inside a section{} inside a dynamicPage{}. What's the best way to do this?
For example, I'd like to....
private drawPicker(inputKey, pickerSuffix = "") {
def inputId = "settings[${inputKey}]";
def colorOptions = COLORS.
collect{ "<option value=\"${it.value}\">${it.key}</option>" }.
join("\n");
// First, the actual ColorMap input for a literal selection
// Everything else transfers its value here.
input inputKey, "COLOR_MAP", title: "", required: true
// Next, inject a color picker (and its scripts) to help with setting
// the map:
def pickerId = "colorPicker${pickerSuffix}"
paragraph """
<input type="color" id="${pickerId}" style="width: 95%;" onChange="
let mapElement = document.getElementById('${inputId}');
mapElement.value = '';
syncColors('${pickerId}', '${inputId}');
<script type="text/javascript">
\$(document).ready(function() {
syncColors("${pickerId}", "${inputId}");
document.getElementById("${inputId}").addEventListener("change", function () {
</script>
""", width: 5
// Then the preset options
paragraph """
<select name="${presetKey}" onChange="
let mapElement = document.getElementById('${pickerId});
mapElement.value = this.value;
syncColors('${pickerId}', '${inputId}');">
${colorOptions}
</select>
""",width: 4
...then invoke this inside a section and have the input and paragraph populate on that page.
