Tuya Zigbee Switch on Hubitat
Switch temporarily to the inbuilt driver called 'device', click on 'Delete all child devices' button and revert back to the driver that is working with this switch. Seems like a very nice find!
Can you also click the 'Get Info' button and copy/paste here the device fingerprint that should appear in the Logs page?
What type of bulbs are you using with this switch? Transcendent or LED?
Also, does the manufacturer advertise the switch to be working without any additional capacitors mounted on the side of the bulbs?
it’s actually an older cfl bulb. now that you mentioned this, i realized that an led would likly not flicker randomly when a signal is repeated. ( i’m assuming this is a repeated signal based on watching the logs, th light flickers just momentarily before the log shows a zigbee device log item.
It's most probably a periodic heartbeat or check-in message generated from the Tuya switch itself. The different models have different check-in transmission periods.
