Tuya Zigbee Siren Alarm (NOOB ALERT)
Setup Hubitat and have added motion and door sensors. Now need to add an alarm. I added a tuya zigbee siren alarm to network but dont see anything for it to do. Just want a simple motion to trigger audio alarm. Seems I may need an app or external code but I will need baby steps guidance. Help a noob out?
Try using the built-in app called Hubitat Safety Monitor (HSM). Install and use as described in the documentation, linked below:
Can you make it sound from the driver page? I assume the driver should be using the Alarm Capability.
Tuya devices are often very temperamental when pairing, seeming to pair the first time, but not actually fully pairing. Try re-pairing the device without first removing it. That is, just go through the pairing process again while putting the device into pairing mode, but don’t remove it from the device list beforehand.
