Tuya zigbee plug
And why again aren't we using the generic zigbee outlet driver with this device?
:crazy_face:
"they claim to use the zigbee 3.0 protocol" ..... 'nuff said.
If you had your HE hub updated to version 2.3.0.123 yesterday, you need to revert back to the previous stable version 2.3.0.121
Critical device data like the model, endpointID, etc.. were playing weird today...
Go to HE Settings page -> Check for updates -> downgrade to 2.3.0.121.
The generic zigbee outlet driver should work with this device, with the exception of receiving the power, voltage, amperage data - these Tuya outlets need polling, they can not be configured to send reports automatically.
Thanks for your reply
dev:3682021-12-26 08:49:48.138 traceZCL version:03
dev:3682021-12-26 08:49:48.134 traceSoftware Build Id:unknown
dev:3682021-12-26 08:49:48.129 traceModel:TS011F
dev:3682021-12-26 08:49:48.125 traceManufacturer:_TZ3000_w0qqde0g
dev:3682021-12-26 08:49:48.070 debuggetting info for unknown Zigbee device...
I hope this helps you and of course me :wink:
above was before downgrade.
after downgrade to 2.3.0.121 this is the reply.
2021-12-26 09:01:57.781 debuggetting info for unknown Zigbee device...
dev:4002021-12-26 09:01:55.106 infoZigbee parsed:[raw:00950100060800001000, dni:0095, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:4002021-12-26 09:01:53.966 infoZigbee parsed:[raw:00950100060800001001, dni:0095, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0]
dev:4002021-12-26 09:01:42.779 debuggetting info for unknown Zigbee device...
I got nothing. with get info. I manually turn the plug on and off. and tried info again.
this is what you get with cheap devices :frowning_face:
'Get Info' is not returning the device fingerprint :frowning:
Most likely the device endpoint is not retrieved and not stored in device Data, this may explain why the inbuilt Generic Zigbee Outlet (and all other drivers) do not work.
Has anyone else seen a similar problem with other zigbee devices?
@kkossev It works !!!
! added a fingerprint profileid in your driver and now it looks like it is working. I can turn the plug on and off. it is recognized when added/discovered
fingerprint profileId: "0104", inClusters: "0003, 0004, 0005, 0006, 0702, 0B04, E001, E000, 0000", outClusters: "0019, 000A", manufacturer: "_TZ3000_w0qqde0g", model: "TS011F", deviceJoinName: "Neo NAS-WR01 Outlet new"
I even get power updates
after having it functional with the changed driver. I tried the get info via device again. and now that works also.
2021-12-26 09:27:12.323 infofingerprint profileId:"0104", endpointId:"01", inClusters:"0003,0004,0005,0006,0702,0B04,E001,E000,0000", outClusters:"0019,000A", model:"TS011F", manufacturer:"_TZ3000_w0qqde0g"
dev:4022021-12-26 09:27:12.237 traceZCL version:03
dev:4022021-12-26 09:27:12.229 traceSoftware Build Id:unknown
dev:4022021-12-26 09:27:12.225 traceModel:TS011F
dev:4022021-12-26 09:27:12.220 traceManufacturer:_TZ3000_w0qqde0g
dev:4022021-12-26 09:27:12.153 debuggetting info for unknown Zigbee device...
As all we already know, these Tuya devices behave very weird... So it may be a combination of different factors, such as partially initialized / corrupted device settings inside TS011F firmware. In such cases removing the plug from the mains power supply for a couple of minutes and then re-initializing the devices again may help.
The important thing is that the devices is working now! :slight_smile:
thanks for your great help. :+1: :+1: :+1:
There is a new driver version that is published here : [BETA] Tuya Zigbee Metering Plug
I understood that the profileid, model number, manufacturer, inclusters and outclusters are different for each product.
I simply followed what @aren did here and added a line in the driver as below.
Remove the device and re-added and it was identified immediately.
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0003,0004,0005,0006,000A,E000,0702,0B04,1000,1888", outClusters:"0019,0021", model:"TS000F", manufacturer:"_TZ3000_xkap8wtb", deviceJoinName: "Tuya Power Monitoring Switch"
All good now.
@kkossev - Is it possible to put in a dynamic popup field for the input values in your driver? Then it will work for any new product as well.
S
Thank you for the fingerprint info, I will add it to the next update of the Tuya driver.
Unfortunately, there is no easy way to provide a dynamic configuration of new devices in a HE driver. What could be done to make the adding of new devices easier is to implement in the driver a generation of the fingerprint the same way, as the HE inbuilt 'device' driver does it.
Can you share a link to the store where this device was purchased?
Thanks @kkossev
Here you go!
Tuya Zigbee MINI Smart Switch Module 16A Wireless Switch Smart Home Smart Life Compatible With Alexa Google Home Yandex
https://a.aliexpress.com/_mrD9252
would these work just for power off and on ..i dont care about power monitor
All Tuya Zigbee plugs that I know of will work for simple On/Off using the HE inbuilt drivers.
There is still some lottery thrill in such purchases - some Tuya devices will not stay connected to the C-8 radio, but hopefully this will be resolved in the future.
thanks good to know...i have a C7 but i who knows if I upgrade would not want things to go south
With Tuya there is no guarantee, but for only $6 a piece ... it is worth the risk.
