Wow..you are the man..It worked like a charm ! Thanks a ton...
Ive just bought a few of these Tuya Smart Wifi/zigbee Door Sensor Door Open / Closed Detectors Wifi Home Alarm Compatible With Alexa Google Home Smart Life App - Window Door Sensor - AliExpress
Doesn't seem to work with the generic driver and after having a search ive come across this thread.
@TOMAS1 Is your driver for this sensor or is yours a different model?
Mines called a zigbee door detector which takes 2 x AAA batteries with a red contact light
Mine has button battery so it's different one. Set it to "device" driver and send me screenshot of Device page (Device Details - Data part), and screenshot of logs when the sensor sends open and close events. Can't promise it will work, but I'll try to add it to this driver.
Ok thank you
Is this what you mean @tomas1 ?
- endpointId: 01
- application: 45
- softwareBuild:
- inClusters: 0001,0003,0500,0000
- outClusters: 0003,0004,0005,0006,0008,1000,0019,000A
- model: TS0203
- manufacturer: _TZ3000_2mbfxlzr
dev:22842022-04-22 19:25:06.524 debuggetting info for unknown Zigbee device...
dev:22842022-04-22 19:24:41.636 infofingerprint profileId:"0104", endpointId:"01", inClusters:"0001,0003,0500,0000", outClusters:"0003,0004,0005,0006,0008,1000,0019,000A", model:"TS0203", manufacturer:"_TZ3000_2mbfxlzr"
dev:22842022-04-22 19:24:41.444 traceZCL version:03
dev:22842022-04-22 19:24:41.439 traceSoftware Build Id:unknown
dev:22842022-04-22 19:24:41.438 traceModel:TS0203
dev:22842022-04-22 19:24:41.437 traceManufacturer:_TZ3000_2mbfxlzr
dev:22842022-04-22 19:24:41.233 debuggetting info for unknown Zigbee device...
The first part, yes. But I those logs are from device init, not from open/close events.
Ok where do I find the open close event logs? Thanks
settings, logs
ok, After deleting the device and re joining it closer to the hub i have some info in the logs
2022-04-24 16:37:29.007 infoZigbee description:zone status 0x0001 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:23162022-04-24 16:37:27.460 infoZigbee description:zone status 0x0000 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:23162022-04-24 16:37:25.836 infoZigbee description:zone status 0x0001 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:23162022-04-24 16:37:18.383 infoZigbee description:zone status 0x0000 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:23162022-04-24 16:37:17.070 infoZigbee description:zone status 0x0001 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:23162022-04-24 16:37:16.627 infoZigbee description:zone status 0x0000 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:23162022-04-24 16:37:09.899 infoZigbee description:zone status 0x0001 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
Now ive re-added it closer to the hub ive used the generic zigbee contact sensor (no temp) driver and it seems to be working
Using Generic Zigbee Contact Sensor driver (no temp) driver (added close to hub) worked for me for Model:TS0203, so thanks!
