I have buyed this Tuya Zigbee Contact Sensor from AliExpress: Tuya Zigbee Contact Sensor
I have no problem pairing it with my HE, but it recognizes it as a Generic Zigbee Motion Sensor.
I have removed the sensor and pairing it again lot of times, pressing configure and refresh, and phisically opened and closed the sensor, but nothing works. I’m quite new with Hubitat and I don’t know if I’m missing something. May be the sensor is broken?
I have tried all of thise drivers and no one works with my device. It also seems that they are not designed for a contact sensor, but for other devices (switches, dimmers...)
Please try Generic Zigbee Contact sensor again for the Tuya sensor you bought, but after you change the driver and click "Save Device", be sure to click the "Configure" button. This sends the parameters of the new device driver to the device.
If the device still doesn't work, please change the driver to "Device", click "Save Device" and then click the "Get Info" button. This will capture the device Fingerprint. Post it here and include @mike.maxwell in the reply.
One other thing you can try Carlos. This has worked often for me when the device fingerprint is not known. Set the driver type to Generic Zigbee Contact Sensor, and then click the Save Device button. Now, without removing the device from Hubitat, pair the device again. HE will say "Found previously joined device Generic Zigbee Contact Sensor" or whatever custom label you gave it. Now try the device again to see if it works as expected.
First of all, thank you everybody for your answers.
I do, but they didn’t work either.
I have done this and now I can see the contact state, but it seems that the device still don’t report because it do not change. It is always “open”.
I got one of these and have the same issues, cannot find any driver that will report open or closed.
However, in Device Information, when I set the Type to 'Device', then I receive the following log messages when closing or opening the contact:
Update: works fine with HE inbuilt 'Generic Zigbee Contact Sensor (no temp)' driver.
The tampering switch is not reported, and there seems to be no temperature or humidity reporting.
