Device is paired as "device" . Logs below with data for fingerprint.
@mike.maxwell can we please add fingerprint? Device seems to work well after manual driver change.
Thank You
2021-04-30 07:05:31.328 pm infoZigbee parsed:[raw:02C9010001102000201D210020BA, dni:02C9, endpoint:01, cluster:0001, size:10, attrId:0020, encoding:20, command:0A, value:1D, clusterInt:1, attrInt:32, additionalAttrs:[[value:BA, encoding:20, attrId:0021, consumedBytes:4, attrInt:33]]]
dev:1962021-04-30 07:05:31.328 pm infoZigbee parsed:[raw:02C90100000801002043, dni:02C9, endpoint:01, cluster:0000, size:08, attrId:0001, encoding:20, command:0A, value:43, clusterInt:0, attrInt:1]
dev:1962021-04-30 07:05:27.207 pm infofingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0001,0003,0500,EF01", outClusters:"0003,0019", model:"TS0207", manufacturer:"_TYZB01_sqmd19i1"
dev:1962021-04-30 07:05:26.464 pm traceZCL version:02
dev:1962021-04-30 07:05:26.457 pm traceSoftware Build Id:unknown
dev:1962021-04-30 07:05:26.455 pm traceModel:TS0207
dev:1962021-04-30 07:05:26.453 pm traceManufacturer:_TYZB01_sqmd19i1
dev:1962021-04-30 07:05:25.516 pm debuggetting info for unknown Zigbee device...
dev:1962021-04-30 07:05:25.263 pm infoZigbee parsed:[raw:02C9010001102000201D210020BA, dni:02C9, endpoint:01, cluster:0001, size:10, attrId:0020, encoding:20, command:0A, value:1D, clusterInt:1, attrInt:32, additionalAttrs:[[value:BA, encoding:20, attrId:0021, consumedBytes:4, attrInt:33]]]
dev:1962021-04-30 07:05:25.260 pm infoZigbee parsed:[raw:02C90100000801002043, dni:02C9, endpoint:01, cluster:0000, size:08, attrId:0001, encoding:20, command:0A, value:43, clusterInt:0, attrInt:1]
sys:12021-04-30 07:05:23.547 pm Created Unknown Zigbee Device
dev:1962021-04-30 07:05:23.495 pm debugconfigure() called...
sys:12021-04-30 07:05:16.943 pm Initializing Zigbee Device EC1BBDFFFEE23957, 02C9
sys:12021-04-30 07:05:15.791 pm Zigbee Discovery Running
from data section
- endpointId: 01
- application: 43
- manufacturer: _TYZB01_sqmd19i1
- model: TS0207
- softwareBuild:
- inClusters: 0000,0001,0003,0500,EF01
- outClusters: 0003,0019
